First, in 7.20 you don't need to look for string in comment to identify containers anymore, you can give them proper name, like pihole for example. Then in the command you can directly reference them, like:
Yes, but also currently repull has the bug that it forgets to put the .type file to the root of the repull-ed container, so all the files and directories are visible when you look at them in WinBox, instead of collapsing into a single container store node.
A fix for now would be to manually create .type file at the root with container as content, by running something like this in the shell.
