Content Filtering
hi, i wanted to know if it possible to filter the url’s or websites based on content or keywords like XXX, porn etc with scripting
Thanks.
Yes, it is possible with proxy.
You can create rules /ip proxy access, regular expressions are supported too there,
Small hits in using regular expressions:
  • \ symbol sequence is used to enter \ character in console
  • . pattern means . only (in regular expressions single dot in pattern means any symbol)
  • to show that no symbols are allowed before the given pattern, we use ^ symbol at the beginning of the pattern
  • to specify that no symbols are allowed after the given pattern, we use $ symbol at the end of the pattern
  • to enter [ or ] symbols, you should escape them with backslash .
i dont want to use the proxy. i wanted to filter using the firewall.
thanks
Firewall does not allow to filter by DNS names.
Sergey, any plans on this topic?
I’d like to buy CCR1036-series device, but…all of a sudden it isn’t capable of filtering by URL. IMHO hardware limitations couldn’t be the obstacle to implement it. Or am I wrong? :slight_smile:
You may try L7 content filtering
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/L7
If this feature really works (I don’t try it), it was your solution for http (not for https)
