This is a script to restore global variables on startup of RouterOS. I’m posting here so others may use/improve it. The main use for me is to prevent ChangeIP script from automatically updating each reboot (as it uses global vars to tell if IP addr changes), and anytime I don’t want to loose a global variable on startup (ex BadIPs). I name this script RestoreGlobalVars and have it Scheduled to run every 15 secs.
Anyway, hope this is useful for anyone.
# this script restores global variables after a startup or reboot
:global RestoreGlobalVars
# if global var isn't set (aka we've rebooted or just started), run restore script
:if ([:len $RestoreGlobalVars] = 0) do={
# if restore script exists, run it
:if ([:len [/system script find name=GlobalVars]] > 0) do={
:log warning "Running GlobalVars script"
/system script run GlobalVars
} else={
:log warning "No GlobalVars script found. Not running."
:global RestoreGlobalVars 1
} else={
# create new source for script
:local globalvars
:set globalvars "# Begin of global variables definition\n"
:foreach var in=[/system script environment find] do={
# do not include RestoreGlobalVars as this is our controlling variable
:if ([/system script environment get $var name] != "RestoreGlobalVars") do={
# only accept name and values that are not blank
:if ([:len [/system script environment get $var name]] > 0) do={
:if ([:len [/system script environment get $var value]] > 0) do={
:set globalvars ($globalvars . ":global " . [/system script environment get $var name] . " \"" . [/system script environment get $var value] . "\"\n")
:set globalvars ($globalvars . "# End of global variables definition")
:if ([:len $globalvars] > 0) do={
# if new source doesn't match existing source, write new source to script
:if ([/system script get GlobalVars source] != $globalvars) do={
:log warning "GlobalVars source changed"
/system script set GlobalVars source="$globalvars"
} else={
/system script add name="GlobalVars" source="$globalvars"
