Hello
I Have an actual situation, as in image below:
Because I think the actual Access point is a very slow equipment, I want to manage this wlan from my RB450G, as in next image
Do you think is possible?
Thanks in advance
NOT POSIBAL CHANGE IP NANO BEAM 192.168.10.102 OR 192.168.10.103 THEN IT IS POSIBAL
YES WLAN CONTROL ED 0NE STATION IP 192.168.10.102 AND OTHER ONE 192.168.10.103
Are you asking how to add a wireless interface to an RB450G?
Hi.
I see 192.168.10.102 twice on both clients. True, or just a mistake ? Can be this the cause of slowness ?
(NanoBeam is not a slow equipment, I use it for streaming video on 6Mbps over 2km link.)
I think, you should put the Ubi-s into transparent bridge mode (with different management IPs), so RB can manage everything other.
Or do you want to use RB450 as central Wifi AP ?
Regards: Xen
The stations have IP 192.168.10.102 and 103.
In the images was a mistake.
In essence I want to setup a wireless connection from rb 450 but the interface is not intetnal, is connected to Eth4 port.
I want to leave the ubiquiti equipments only as a link betwen this 3 point and all parameters ( ssid,encryptions,etc) to be seting up from rb450.
If I understand you correctly, then no, you can’t do what you’re asking. CAPsMAN allows you to manage multiple Mikrotik radios from a central point, but it’s proprietary so isn’t going to work with Ub****ti equipment.
