hello dear expert
i have configured pcc loadbalancing in my net cafe…
and its working perfect but the problem is winbox not open from my home through internet
i want to control winbox from my home through internet..
plzz see diagram
sorry for bad english…
/ip address export
/ip service export
And post back.
see diagram above…
Check Destination-NAT/Port-Forwarding on your DSL1/DSL2 devices.
Also IMHO you should consider to put DSL1/DSL2 devices to ‘bridge mode’ and do masquarade on MikroTik.
In this case public IP will be on MT interface and clients will be NATed only one.
Currently your clients (10.10.0.0/24) are behind double NAT, so try to make things simpler
HTH,
1=port forward in both modems
2=if i unplug one modem its working
plz help
It seems that problem is with PCC loadbalancing and default route.
If you unplug one DSL, there is only one default route/gateway and it works.
With PCC load balancing you should also set routing marks for incoming connections.
So check your config twice.
HTH,
exactly…with one dsl its working perfect but with pcc its not working…
here is my config…
ip route
add check-gateway=arp comment="WAN 3 - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=wan3
add check-gateway=arp comment="WAN 2 - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=wan2
add check-gateway=arp comment="WAN 1 - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=wan1
add check-gateway=arp comment="WAN 1 - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=wan1
add check-gateway=arp comment="WAN 2 - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=wan2
add check-gateway=arp comment="WAN 3 - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=wan3
add check-gateway=arp comment="WAN 1 - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=wan1
add check-gateway=arp comment="WAN 2 - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=wan2
add check-gateway=arp comment="WAN 3 - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=wan3
add check-gateway=arp comment="Default Route - Distance 1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1
add check-gateway=arp comment="Default Route - Distance 2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.2.1
add check-gateway=arp comment="Default Route - Distance 3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=192.168.3.1
add check-gateway=arp comment="Static Route - WAN1" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=static-wan1
add check-gateway=arp comment="Static Route - WAN2" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=static-wan2
add check-gateway=arp comment="Static Route - WAN3" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=static-wan3
ip firewall mangle
add action=mark-connection chain=input comment="Mark new inbound connection wan1" connection-state=new disabled=no in-interface=Wan1 new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=input comment="Mark new inbound connection wan2" connection-state=new disabled=no in-interface=Wan2 new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=input comment="Mark new inbound connection wan3" connection-state=new disabled=no in-interface=Wan3 new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=prerouting comment="Mark established inbound connection wan1" connection-state=established disabled=no in-interface=Wan1 new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=prerouting comment="Mark established inbound connection wan2" connection-state=established disabled=no in-interface=Wan2 new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=prerouting comment="Mark established inbound connection wan3" connection-state=established disabled=no in-interface=Wan3 new-connection-mark=wan3 passthrough=yes
add action=mark-connection chain=prerouting comment="Mark related inbound connection wan1" connection-state=related disabled=no in-interface=Wan1 new-connection-mark=wan1 passthrough=yes
add action=mark-connection chain=prerouting comment="Mark related inbound connection wan2" connection-state=related disabled=no in-interface=Wan2 new-connection-mark=wan2 passthrough=yes
add action=mark-connection chain=prerouting comment="Mark related inbound connection wan3" connection-state=related disabled=no in-interface=Wan3 new-connection-mark=wan3 passthrough=yes
add action=mark-routing chain=output comment="Mark new inbound route wan1" connection-mark=wan1 disabled=no new-routing-mark=static-wan1 passthrough=no
add action=mark-routing chain=output comment="Mark new inbound route wan2" connection-mark=wan2 disabled=no new-routing-mark=static-wan2 passthrough=no
add action=mark-routing chain=output comment="Mark new inbound route wan3" connection-mark=wan3 disabled=no new-routing-mark=static-wan3 passthrough=no
add action=mark-connection chain=prerouting comment="Mark traffic that isn't local with PCC mark rand (3 possibilities) - option 1" connection-state=new disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="Mark traffic that isn't local with PCC mark rand (3 possibilities) - option 2" connection-state=new disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan2_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="Mark traffic that isn't local with PCC mark rand (3 possibilities) - option 3" connection-state=new disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan3_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-connection chain=prerouting comment="Mark established traffic that isn't local with PCC mark rand (3 possibilities) - option 1" connection-state=established disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="Mark established traffic that isn't local with PCC mark rand (3 possibilities) - option 2" connection-state=established disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan2_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="Mark established traffic that isn't local with PCC mark rand (3 possibilities) - option 3" connection-state=established disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan3_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-connection chain=prerouting comment="Mark related traffic that isn't local with PCC mark rand (3 possibilities) - option 1" connection-state=related disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0
add action=mark-connection chain=prerouting comment="Mark related traffic that isn't local with PCC mark rand (3 possibilities) - option 2" connection-state=related disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan2_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/1
add action=mark-connection chain=prerouting comment="Mark related traffic that isn't local with PCC mark rand (3 possibilities) - option 3" connection-state=related disabled=no dst-address-type=!local in-interface=Lan new-connection-mark=wan3_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/2
add action=mark-routing chain=prerouting comment="Mark routing for PCC mark - option 1" connection-mark=wan1_pcc_conn disabled=no new-routing-mark=wan1 passthrough=yes
add action=mark-routing chain=prerouting comment="Mark routing for PCC mark - option 2" connection-mark=wan2_pcc_conn disabled=no new-routing-mark=wan2 passthrough=yes
add action=mark-routing chain=prerouting comment="Mark routing for PCC mark - option 3" connection-mark=wan3_pcc_conn disabled=no new-routing-mark=wan3 passthrough=yes
