Ciao rextended!
After all these years, I'm still using your wonderful scripts and I'm very happy with them (thanks). But RouterOS has changed a lot, and I'm optimizing the related scripts, especially those concerning Date/Time, for the latest RouterOS versions.
Regarding "datetime2epoch," I'd like to reduce it as much as possible to adapt it only to the current format, "2023-04-13 09:30:00." What do you think?
Original version by rextended (all versions)
:global datetime2epoch do={
:local dtime [:tostr $1]
/system clock
:local cyear [get date] ; :if ($cyear ~ "....-..-..") do={:set cyear [:pick $cyear 0 4]} else={:set cyear [:pick $cyear 7 11]}
:if (([:len $dtime] = 10) or ([:len $dtime] = 11)) do={:set dtime "$dtime 00:00:00"}
:if ([:len $dtime] = 15) do={:set dtime "$[:pick $dtime 0 6]/$cyear $[:pick $dtime 7 15]"}
:if ([:len $dtime] = 14) do={:set dtime "$cyear-$[:pick $dtime 0 5] $[:pick $dtime 6 14]"}
:if ([:len $dtime] = 8) do={:set dtime "$[get date] $dtime"}
:if ([:tostr $1] = "") do={:set dtime ("$[get date] $[get time]")}
:local vdate [:pick $dtime 0 [:find $dtime " " -1]]
:local vtime [:pick $dtime ([:find $dtime " " -1] + 1) [:len $dtime]]
:local vgmt [get gmt-offset]; :if ($vgmt > 0x7FFFFFFF) do={:set vgmt ($vgmt - 0x100000000)}
:if ($vgmt < 0) do={:set vgmt ($vgmt * -1)}
:local arrm [:toarray "0,0,31,59,90,120,151,181,212,243,273,304,334"]
:local vdoff [:toarray "0,4,5,7,8,10"]
:local MM [:pick $vdate ($vdoff->2) ($vdoff->3)]
:local M [:tonum $MM]
:if ($vdate ~ ".../../....") do={
:set vdoff [:toarray "7,11,1,3,4,6"]
:set M ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" [:pick $vdate ($vdoff->2) ($vdoff->3)] -1] / 2)
:if ($M>12) do={:set M ($M - 12)}
:if ($vdate ~ "....-...-..") do={
:set vdoff [:toarray "0,4,6,8,9,11"]
:local yyyy [:pick $vdate ($vdoff->0) ($vdoff->1)] ; :if ((($yyyy - 1968) % 4) = 0) do={:set ($arrm->1) -1; :set ($arrm->2) 30}
:local totd ((($yyyy - 1970) * 365) + (($yyyy - 1968) / 4) + ($arrm->$M) + ([:pick $vdate ($vdoff->4) ($vdoff->5)] - 1))
:return (((((($totd * 24) + [:pick $vtime 0 2]) * 60) + [:pick $vtime 3 5]) * 60) + [:pick $vtime 6 8] - $vgmt)
Optimized version only for v7.10+ (Is that correct?)
/system clock
:local MM [:pick $vdate ($vdoff->2) ($vdoff->3)]; :local M [:tonum $MM]
