Hello i’m a beginner about mikrotik
i just wanna asked about, can mikrotik routerboard used converter USB to LAN??
Because at my routerboard no USB port so i try to used the converter
it’s will be work or not??
An ethernet to USB converter will add an ethernet port to a device with USB ports, not an USB port to a device with ethernet ports to provide some kind of remote USB functions. So no, it will not work as you want it to.
