Hi, how to use this script http://wiki.mikrotik.com/wiki/Cool_Console ?
Have I to preapre branding maker package with this script?
Save the code in a new script, and then run it. Then open a new terminal in winbox, or login via telnet/SSH to see the new logo.
Basically all it does is update the system note that will be displayed when someone logs in.
Thank you. I’ve checked. In ros 6.x first is loaded logo from branding maker, next short info about commands, after that the console script.
I have a asci image
Glad to see someone also used my scripts ![]()
:local content
:local i
:local logcontenttemp “”
:local logcontent “”
:set logcontenttemp “:.you are logged into: $[/system identity get name]
:set logcontent (“$logcontent
" .”$logcontenttemp" .“\n\r”)
:set logcontenttemp “******************** system health ********************”
:set logcontenttemp “uptime: $[/system resource get uptime] d:h:m:s”
:set logcontenttemp “cpu load: $[/system resource get cpu-load]%”
:set logcontenttemp (“free memory: $([/system resource get free-memory]/1048576)m”)
:set logcontenttemp “voltage: $[:pick [/system health get voltage] 0 2] v”
:set logcontenttemp “temperature: $[ /system health get temperature]c”
:set logcontenttemp “******************************************************"
/system note set note=" zee.
_
\n z=. .P" $
_
\n % ^c z" $
_
\n b % d 4"
_
\n 4 $ … 4" $
_
\n F L .P" "%. $ $
_
\n $ 4 e" "c " $
_
\n $ F z" * 4 $
_
\n P $ d 3.$ $
_
\n % $d ..eeeec.. $ 'b
_
\n d $% .e$c d" ".z$%. $ $
_
\n F $ e" $ F $ ^F.db.$ b
_
\n J $d\" ^$ 4b $ $ 3/$ *
_
\n $ $$ $c P P" * ."F .$$ b
_
\n 4F $ $c .EeP"" ^C$$..F F $
_
\n J $ $."-". ." "b$ F 'r
_
\n $ "$ zc. .. -"..-""\ $$% $
_
\n $ $ .. L P ebe 4$ $
_
\n $ ^F d%$J%3 $ $ " 4F $
_
\n * 4b @ 3 ^r 4$ $
_
\n 4 d$. 4 $3. 4F
_
\n L $$. %$ $ J
_
\n $ d $ $ - ^. P $c $ $
_
\n r z".$L L .$%..$ J $P. . d
_
\n " z" P$$ ^% z" ". L d$$"c "e z%
_
\n * .P .$$$ "*" .$c $$$$.b ^$"
_
\n *$ dL$$$$r ^4. ./" ""%..r" $$$$$$J$e"
_
\n $b$$$$$$F "" $$$$$$$P
_
\n ^$$$$$$$$ $$$$$"
_
\n "$$$$ $"
_
\n ’ 4
_
\n * $ .$ F
_
\n % 4F .$ "
_
\n *$% .$dr
_
\n . .
_
\n ".."
\n $logcontent”
cool
