Is it possible to copy the config from one router to another router? I want to duplicate the config I have and just change the address ranges.
Thanks ![]()
Thanks ![]()
Yes, you can use export - import command.
You’ll need to edit the file to put items in the proper order and remove macs and other unique entries. Otherwise a mess will result.
