Copy multicast between two bridges
We have 2 bridges: bridge1 and bridge2.
Whether there is a possibility of copying a multicast between bridges?
Regards,
Igor
Give IGMP proxy a try…
Good day!
I trying igmp proxy, but no result.
As upstream I select bridge1 and downstream I select bridge2.
Regards,
Igor.
to start passing you have to have a request on downstream interface.
Or you can add static MFC entry in /routing igmp-proxy mfc
Is it possible to add MFC static entries from Winbox? I haven’t found it yet…
No, only from console.
