After using this software for about 3 months now, I’ve decided I need to break some of my network down and put those devices in submaps. Can anybody tell me if its possible to move a device that’s already been entered to another map? I realize there is no copy and paste, but what about the xml file? Can it be edited to move one item to another map?
Not yet. Maybe on future releases they implement this. Dont use the copy button at the network map settings window before do a backup. It will open a new map window and then, if you click ok, you will end with two network maps sharing info each other. I was unable to retrieve the original map back after this. I didnt checked if “undo” works on this. I just did a reload on a recent backup file to fix the mess and lost about a minute of data.
