Core router options
Hi all!
I have been reading and searching but just in case I woud like few pointers pl so I dont buy cat in the bag :slight_smile: !
My ayes are stuck on RB1100ahx2 for core router for small wisp project!
RB woud have to handle: -
PPPoE max 200 conections with user-manager
  • Firewall
  • QoS
  • logging users activities (for starters on SD 16gig disk , to bad there is no RB product with sata disk possibility :frowning: )
  • No more then 50-60 Mbits of trafic form WAN to bridge network!
    Basically I woud like to do evrything with one box, no extra servers and devices at least for now !
Woud this device do the job ?
Thx !
Hello Makoto,
you not wrote what speeds will be assigned to clients.
With my experience 1100AHx2 will not handle 200 users with shaping. it crashes when load reaches 50mbit/s
You should look to CCR.
+1
I definitely agree, the CCR is better than the RB11xx series in every way.
Thx for advice so I am left to go with CCR or some x86 custom thing !
Thx for tips , I whill look into CCR and other options.
16 core model should be sufficient ? I whant to get good thing but at the same time be careful with my budget :slight_smile: .
A router for 200 PPOE-Sessions is a central component. You should plan enough Budget for it.
So go with the bigger CCR as it is cheap anyway. If you have to argue get the pricing for a juniper/cisco.
