1 - “I wouldnt bother with regex layer7…”
This rule exists to block in firewall rules “Bloqueio sem”, “Bloqueio sex” and "“Bloqueio sem dom” lock pc of my children.
released only on weekends.
2 - “it would appear you have two…”
Yes, i have two links, 2 wans.
3 - “You have weird MTU settings…”
This settings valid only my VPN local server on my mikrotik
4 - “You seem to have a subnet spread…”
I resolve divide my network, because i use ether5 wired network and ether4 to wifi network, my wifi router dont used as nat, used only transmitter wifi.
5 - “You have a set of complex firewall rules…”
Basically, on all “Interfaced List” internet, i drop all packages except, myvpn and ping (icmp), and drop all output except what is needed for sevices like vpn, cloud, etc.
6 - “In terms of routes I see the proton route…”
I use distance because i have two wans and proton, i use failover configuration, but in some cases i force to use especific out wan to access some services.
As I don’t want use ProtonVPN on all clients i decide create a “Routing Table” on mikrotik.
As there are 3 WANs (Wan1 dhcp, Wan2 pppoe, ProtonVPN), it is necessary to use distances.
7 - “You have two mangle rules…”
“RotaVPN Full” and “RotaVPN” are similar rules, both attempts to make it work.
On “RotaVPN” i put x.com on “RotaVPN” it is “Address Lists” to test and another sites, this works.
The problem is paramontplus.com, when add on list or activate “RotaVPN Full”
return erro 406, i dont understand why.
On “RotaVPN Full” Until resolve this problem on paramontplus.com i solate to my pc for tests
8 - “Can you confirm that the router…”
Yes, i am developer and i use it for “cheat” my dns resolver an redirect to my pc for tests, etc..
9 - “Seems to be okay, just added passthough=no…”
I altered this rule but paramontplus.com persists on error 406.
10 - “Overall Summary. You should scrap your entire config…”
For testing I could, but I don’t think it would make paramontplus.com work.
If disable routing mark “RotaProtonVPN” paramontplus.com works fine, on wan1 or wan2.
Obviously it is not a firewall rule, or routes problem, if i force second wan Address List “Claro” routing table “RotaClaro” paramontplus.com works perfectly.
Only if activate route mark to ProtonVPN return error 406.
If i use same server ProntonVPN directly in my pc or celullar paramontplus.com works
I believe it is a simple question, but I cannot see a solution.
