I am having trouble typing in the following text at the command line that I copied off of the wiki:
[admin@MikroTik] ip firewall mangle> add src-address=10.0.0.0/24 mark-flow=p2p-out
... p2p=all-p2p action=passthrough
[admin@MikroTik] ip firewall mangle> add dst-address=10.0.0.0/24 mark-flow=p2p-in
I can change into ip/firewall/mangle no problem.
When I type in the command I get a red block on the letter m on mark. What is the exact text I would type in at the command line? the \ and … confuse me. (Yes I’m new at this) Also is there any guide or tips when it comes to typing at the command line?
You can also hit tab twice to see all available options in your current menu. Also you can enter in a ‘?’ to see available commands and a brief explanation.
