Hello guys … I’m new at this of working with MikroTik RouterOS and I have to access one from a Public IP. I’ve been ready the docs and the forums about this cuestion and tried some of the things you say … but it didn’t work.
Could you please tell me the correct and complet process for accesing the router with the Winbox from a Public IP using 8291 port.
192.168.101.1 is the router private IP as you can supose … and if I access the public IP through an explorer it downloads the configuration page … if I login a see on the logs of the router that xxx user has logged with the public IP from were I navigate. So that parts seems to work. But the 8291 port non
Does your RouterOS router have the public ip address 213.x.x.x itself? Or is it sitting behind the router with the public ip address?
I would check possible firewall rules for ones that deny logging in from external addresses?
If it directly HAS the public ip address, just remove all those dst-nat and firewall rules, then you can just connect to the public ip address…
Best regards,
Christian Meis
PS: Putting your router on the internet that way without securing it further might (and should ) be considered bad practice. At least shut down the telnet service (/ip service) etc. There are examples in the Wiki how to secure your router…
OK … I disabled all de dst-nat and firewall rules … it seems to do something … it downloaded something … but it didn’t connect. All the next time … it doesn’t connect.
