Could not change the key - invalid key
I have a 532A RouterBoard with V4.4 on it. This unit has been working this way for the past couple of months until one day I logged into Winbox and it said that the license would expire in 24 hours. I tried getting a hold of tech support but it was too late before the time ran out. I have been given a new key but when I try and install it, it keeps saying “could not change the key -invalid key”. I have tried this in Winbox, the new terminal window, and Hyperterminal. If someone could give me a clue on what I might be doing wrong I would really appreciate it. Is it possible the board is damaged for why it is not taking the key? Thank you in advance.
import the attached file with the command ‘/system license import’ (you must upload the licence key to the router’s FTP server)
I am reading on how to do that now. I got the key in an email as text. It starts with ---------BEGIN MIKROTIK KEY— and then there are 2 lines of characters and then the same line to end it. Do I make a *.key file and upload that to the ftp server, or do I cut out the -------BEGIN MIKROTIK KEY----- part.
Thanks again.
Open notepad. Copy your licence key from email ect.
-----BEGIN MIKROTIK SOFTWARE KEY------------
lZDo1eSf3egdI/T2hY8fY8OygIZ+UJucjVfOS2+CY+RT
McnWOukAdhiQj5HlNLr7+jUlVoEqlqvgACA5X2qbLD==
-----END MIKROTIK SOFTWARE KEY--------------
and paste it into notpad. Then Sava As ect. NNFT-86N.key
Then take key and upload it to ftp server.
Finaly open new terminal and type in
The file is on the ftp server now and below is what I’m getting in the new terminal window. The file contains the key the way you described above.
[admin@CCCS MikroTik] > /system license import file-name=new1.key
failure: invalid key
failure: no new key found
[admin@CCCS MikroTik] > /system license import 1QGK-56XD.key
expected end of command (line 1 column 24)
[admin@CCCS MikroTik] > /system license import file-name=1QGK-56XD.key
did you try to lose your key?
 /system license> lose-key
Do you really want to lose software key? [y/N]:
Okay I tried that and the router rebooted and then it seems it lost all of the configurations. I had to use netinstall to get it back up again and it seems the key was still in there. Maybe I will request a new key. I have a new routerBOARD on the way from a supplier but I was hoping to at least salvage this and not have to redo everything every 24 hours.
yup.. maybe someone else can help u.
a this moment, try to install 3.30 that should recognise your old license key, when you do that, create supout.rif file and send it to support@mikrotik.com
when license issue is resolved you will be able to update to 4.4 and use it without problems.
It will say “Invalid key” only in one case: Your key was made for a different SoftID than you have in System License now.
You must check why that is.
I have got the same error. This is a stock standard RB411A that I bought 3 months ago.
It was plugged in, upgraded to V4.6 and when I hit “Update License key” I got the result: “Could not change the key - invalid key”
Is there anything I can do to correct this?
Cheers
Have you solved?
read my reply above !
Hi Normis,
I have similar problem on RB532A and i have opened a ticket to your support.
good, then why post here? other users can’t make a new key for you.
Good afternoon inadvertently put this command / system license> lose-key
Do you really want to lose key software? [y / N]: -
and delete the license to my rb and retrieve it but I have 24-hour license
is again the team I have even a month
how could I get my original license L4
