could not connect to console, try rebooting the router
Connection terminated.
I got the message above trying to telnet or ssh to the MT box.
The box work fine for about a month and then it’s telnet and ssh service got stuck.
I tried to restart the services but it didn’t help.
Only thing that helps is to reboot the router which in my case isn’t very good idea.
I checked every change from 3.0 to 3.13, and there is no fix for anything similiar.
There is also a couple of the posts here with almost same problem unsolved for ppl using 3.0rc6 - 3.9.
On the next “stuck” i will upgrade the router to latest one and see if it’s gonna happen again.
That would be probalby in about 2 months…
I do not use RB, and the router is working perfectly (all other functions except this problem with telnet/ssh).
I hope the upgrade won’t mess the ton of rules i use on that router.
