I reseted it
Need help urgently!
I have reset reset it several times because I need to delete the default configuration. But when the default configuration is deleted, I can’t access to the router via MAC!
I think I have tried everything and I need suggestions from the experts
Greetings!
I have tried this and have/had the same problem on 2 SXT’s
It turns out that after setting up the bridge (i made aPTP bridge) it doesn’t want to connect anymore and i got the error:
“could not connect to (port 20561) timed out!”
After resetting the device (i did have access throu IP) i could also connect throu MAC.
