Could not connect to [MAC] (port 20561) - timed out!
I can connect only to IP address (RB751U-2HnD).
When i try connect to MAC-address (on any port), i always get error:
RouterOS WinBox Error
any suggestion?
Hi
I have the same issue, does anybody have any suggestions?
regards
Hi
I have resolved the issue on my side.
I had a host only network for virtual box, as soon as I removed that, it worked again.
I have two RB751U-2HnD as WiFi bridge (Mikrotiks without ip-addresses)
Bridge work, but i can connect only to one Mikrotik!
Other Mikrotik always show:
(i do not have any virtual network adapters on my PC)
any suggestions?
Try different computer, or disable laptops wifi card.
try this
Neighbour viewer for Windows
http://www.mikrotik.com/download/neighbour.zip
at your computer network disable any virtual network and it will work …
Can you mactelnet from one to the other?
