could not fetch index from $ip_address (port80): Not found
Dear all,
I have some problems with my mikrotik router. I activated the hotspot, and then I tried to connect to mikrotik use WinBox, and It can’t. The error is : “could not fetch index from $mikrotik_ip_address (port80): Not found”
Any body Can help me to solve my problem above?
Thanks before.
:slight_smile:
If you’re connecting on the side that you just activated the hotspot on then you need to login first.
If not, try using :8291 where you specify the IP address in winbox
I am having the same problem. Kindly guide me. I am also attaching the setting my dsl modem.
Thank you.
Muhammad Fawad
