Searching some around for the problem, but dont find any realy good answer in the forum to the winbox message: Could not get index: fatal error
This apper when i try to connect to routeros trough winbox by IP. If I connect directly to the wirelessAP, i can get contact by mac address, or by serial cable. It seems like an issue related to IP addres. There are also an error in ssh/telnet web: just get the error: Connection closed by foreign host (telnet to port 21,22,23 and 80) (i think this is related)
Anyone that have an idea of what this can be? I have gone trough the whole AP, and cant find any access list etc that should make the “error”. I have tried from different PC’s and “dirrerent IP’s” (at bridge, ether1, PPPoE and wlan1), but still cant connect.
I run RouterOS 3.0rc13 with level4. It seems like it is an issue in erlier version to (it is written some in the forum earlier)
mine says: “could not get plugin index!” in 2.9.6
i just upgraded to 3.0rc13 and STILL the same error
If i change the IP to be dynamic so the hotspot server gives me the IPs then i can connect using 10.0.0.1
but if i try to connect with my PC being static and one of the routeros interfaces being 192.168.0.2 i get this error.
[admin@Shahrazad] /ip address> print
# ADDRESS NETWORK BROADCAST INTERFACE
0 I 172.16.0.1/16 172.16.0.0 172.16.255.255 wlan1
1 10.0.0.1/8 10.0.0.0 10.255.255.255 ether2
2 192.168.0.2/24 192.168.0.0 192.168.0.255 ether1
again…
it makes no sense cause ether1 is .02 and i should connect to it fine.
but i cant. i can only connect by going to 10.0.0.1 by doing my pc dhcp and getting ip from hotspot dhcp server.
I see U have an I flag - inavlid to the address on the wlan interface. May this be the issue? i’ll check mine to see if there may be som invalid IP’s (dont think so)
I have had same problem on my v3.16 on RB433.
Winbox access routerboard only per MAC
I try to secure my routerboard and I set in IP->Service for winbox to be aviable From 192.168.0.0/24. (There is wrong mask.)
After I return settings back to 0.0.0.0/0, problem has ben solved.
I try also 192.168.0.0/16. That works OK.
I am getting this error too.
My routeros is at version 3.25 ( RB433 ).
Infos:
[admin@MikroTik Vila Mariana] /ip address> print
0 10.100.3.2/24 10.100.3.0 10.100.3.255 MPLS
1 200.207.212.XXX/26 200.207.212.0 200.207.212.63 Internet
2 192.168.0.1/24 192.168.0.0 192.168.0.255 LAN
3 D 172.16.1.2/32 172.16.1.1 0.0.0.0 VPNB_Lorena_512k
4 D 172.16.0.2/32 172.16.0.1 0.0.0.0 VPNA_Diveo
Firewall:
1 200.207.212.52/26 200.207.212.0 200.207.212.63 Internet
I am not able to connect to mk at IP 10.100.3.2. I always get this fatal error.
