Hi, I wanted to know if anybody could audit my firewall rules, to find optimizations, flaws or else.
Setup is basic, 1WAN, 1LAN (172.16.0.0/16), 1DMZ (192.168.1.0/24).
LAN and DMZ can go to WAN, DMZ and WAN can only respond to LAN if initiated by LAN.
[REDACTED@MikroTik] > /ip firewall export
# 2024-10-04 12:22:38 by RouterOS 7.15.3
# software id = Y101-UNBL
# model = CCR2004-16G-2S+
# serial number = REDACTED
/ip firewall address-list
add address=172.16.0.0/16 list=here
set udp-timeout=10s
add action=accept chain=input comment="defconf: accept ICMP" in-interface-list=LAN protocol=icmp
add action=accept chain=input comment="accept from LAN" in-interface-list=LAN
add action=drop chain=input comment="default action DROP"
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="drop DNS req to outside" dst-port=53 in-interface-list=LAN protocol=udp src-address=!172.16.1.1
add action=drop chain=forward dst-port=53 in-interface-list=LAN protocol=tcp src-address=!172.16.1.1
add action=accept chain=forward comment="accept LAN to WAN" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="accept LAN to DMZ" in-interface-list=LAN out-interface-list=DMZ
add action=accept chain=forward comment="accept DMZ to WAN" in-interface-list=DMZ out-interface-list=WAN
add action=accept chain=forward comment="accept port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="default action DROP"
add action=masquerade chain=srcnat comment=hairpinning disabled=yes dst-address=192.168.1.0/24 src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="out nat" out-interface-list=WAN
add action=jump chain=dstnat dst-address=REDACTED jump-target=port-forward
add action=dst-nat chain=port-forward comment="" dst-port=4222 protocol=tcp to-addresses=192.168.1.15 to-ports=22
add action=dst-nat chain=port-forward comment="" dst-port=4282 protocol=tcp to-addresses=192.168.1.15 to-ports=4282
add action=dst-nat chain=port-forward comment="" dst-port=4221 protocol=tcp to-addresses=192.168.1.15 to-ports=21
add action=dst-nat chain=port-forward comment="" dst-port=40101-40200 protocol=tcp to-addresses=192.168.1.15 to-ports=40101-40200
add action=dst-nat chain=port-forward comment="" dst-port=3306 protocol=tcp to-addresses=192.168.1.15 to-ports=3306
add action=dst-nat chain=port-forward comment="" dst-port=8443 protocol=tcp to-addresses=192.168.1.15 to-ports=8443
add action=dst-nat chain=port-forward comment="" dst-port=443 protocol=tcp to-addresses=192.168.1.16
add action=dst-nat chain=port-forward comment="" dst-port=80 protocol=tcp to-addresses=192.168.1.16 to-ports=80
add action=dst-nat chain=port-forward comment="" dst-port=4443 protocol=tcp to-addresses=192.168.1.14 to-ports=4443
add action=dst-nat chain=port-forward comment="" disabled=yes dst-port=4380 protocol=tcp to-addresses=192.168.1.17 to-ports=80
add action=dst-nat chain=port-forward comment="" disabled=yes dst-port=4322 protocol=tcp to-addresses=192.168.1.17 to-ports=22
add action=dst-nat chain=port-forward comment="" dst-port=4580 protocol=tcp to-addresses=192.168.1.45 to-ports=80
add action=dst-nat chain=port-forward comment="" dst-port=4543 protocol=tcp to-addresses=192.168.1.45 to-ports=443
add action=dst-nat chain=port-forward comment="" dst-port=26000-28000 protocol=tcp src-port="" to-addresses=192.168.1.88 to-ports=26000-28000
add action=dst-nat chain=port-forward comment="" dst-port=26000-28000 protocol=udp to-addresses=192.168.1.88 to-ports=26000-28000
add action=dst-nat chain=port-forward comment="" dst-port=25555 protocol=tcp to-addresses=192.168.1.88 to-ports=22
Thanks !
