Hi, here’s my configuration
name=“Radio” mtu=1500 mac-address=00:0C:42:05:01:53 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“Solusindo Bintang Pratama” mode=ap-bridge ssid=“Solusi”
area=“” frequency-mode=manual-txpower country=indonesia antenna-gain=16
frequency=2412 band=2.4ghz-b/g scan-list=default rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps
max-station-count=1024 ack-timeout=dynamic tx-power=30
tx-power-mode=card-rates noise-floor-threshold=default
periodic-calibration=enabled burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=yes security-profile=default
disconnect-timeout=10s on-fail-retry-time=100ms preamble-mode=long
compression=no
I have 38 clients on this AP, and when i change the channel, my client couldn’t associated with my AP. I have to go back on channel 2412 for my client to associate with my AP. What’s wrong with my configuration? Would someone please tell me? Thank you.
