I have a problem in my 411 board,the problem is i couldn’t make bandwidth test…
What i have done is i’ve used two 411 boards one as Bridge and another as station wds,
The RSSI is 52 ,but i am unable to do bandwidth test.
Thanks in Advance
post settings of your bandwith-test server and client.
I usualy make mistake and forgot to type in username and password in BT client
Also remember not to use the RB411s used for the link as the bandwidth client and server. Creating and terminating packets is very different from forwarding them. Put another router or computer behind each 411 and run the test between those.
fewi is right.
one of primary testing rules is: Never test equipment using tested equipment. (use external tools).
Yes when i use rb433 as Ap ,i am able to do bandwidth test,
I guess it is because when i’m using 411 on both sides this problem occurs …
So now i’ve changed the Ap equipment to 433 n now i’m able to do btest …
I ve done ftp also using filezilla but i couldn’t transfer files
