Couldn't remove NAT Rule ... notpermitted
ros 7.4 show "couldn’t remove NAT Rule … notpermitted "when removing upnp nat.What is the soluation?
Disable and re-enable upnp, or tell to programs you use to release the rule, or set it to do not lock a port with upnp.
Thanks for the reply.But disable upnp delete all the dynamic nat rule.
Yes, all dynamic rules opened from UPNP (not generically “any” dynamic rules)
Instruct the application to close the ports, and the rule is deleted.
