"Couldn't remove Wireguard peer - can't remove dynamic object
I tried using the new “back to home” app, and this peer was automatically created. I cannot remove it, nor can I remove a related NAT entry nor a related filter rule. I understand that the dynamic entries are created and removed automatically, and that they have a parent item, but I don’t know how to locate the parent item to remove it. I am not able to set up a new tunnel with Back to Home at this point (it keeps adding new peers, which can easily be removed, but no new WG instance.
Any ideas? Thanks!
The comment on NAT entry will show you that it’s “back-to-home”, so it all comes to
ip/cloud/set back-to-home-vpn=revoked-and-disabled
