I’m getting this error when trying to restore a general configuration I use as a template on the RB411 for customer CPEs (no sense in reentering that info again and again). The board is running V3.10. I also experienced this on the Crossroads board using V3.13.
Use Terminal.
[admin@Hotspot] /system backup>
load
file name
that works
good luck
Thanks!
[henno@router] > file/print
Columns: NAME, TYPE, SIZE, CREATION-TIME
# NAME TYPE SIZE CREATION-TIME
0 backup_config.rsc script 25.8KiB mar/28/2023 14:15:20
1 single-bridge-conf-wip.rsc script 27.3KiB mar/28/2023 16:50:29
2 flash disk jan/01/1970 03:00:00
3 flash/ca.crt .crt file 1797 feb/08/2019 18:27:18
4 flash/server.crt .crt file 5.5KiB feb/08/2019 18:27:34
5 flash/skins directory jan/01/1970 03:00:02
6 flash/server.pem .pem file 1679 feb/08/2019 18:32:24
7 flash/pub directory jul/18/2018 13:21:00
[henno@router] > /system/backup/
[henno@router] /system/backup> load
password:
Restore and reboot? [y/N]:
y
Restoring system configuration
Failed to restore system configuration
file not found
What other options are there?
You realize you are responding to a 15 year old thread…
With that said, there are two script files there, but not a backup config file.
