hi there
i have problem with many games it happened when i install routerboard microtik ,when i make counter strike server the clients can not see the server,i use hotspot for clients and i fix that when i change ip from the client to another ip to fix it, but this problem not happen with same client it is change to another clients
Try setting the address pool of the Hotspot server to ‘none’ to prevent it from ARP poisoning the network.
thank’s for u r help i will try it
it is work perfect thank’s
