CounterStrike in Mikrotik network
Hi , i want to run the counterstrike in my mikrotik network when i run it i can’t see any player on the netwrok ,
can i get help on this ..
more info needed.
type of network, how configured, post drawing:
http://forum.mikrotik.com/t/getting-the-most-out-of-this-forum/40983/1
thanks for your replay , i have normal setup 2 network adapters one for lan and one for internet and has the ips bellow
[admin@MikroTik] > / ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 10.1.1.1/24 10.1.1.0 10.1.1.255 ether2
1 D 94.97.215.73/32 84.235.124.5 0.0.0.0 pppoe-out1
i configure the firewall rules as listed bellow :
[admin@MikroTik] > /ip firewall filter print
0 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
1 chain=virus action=accept protocol=tcp dst-port=1363
2 X ;;; ndm server
chain=input action=drop protocol=tcp dst-port=21-24
3 ;;; screen cast
chain=virus action=drop protocol=tcp dst-port=1368
4 ;;; hromgrafx
chain=virus action=drop protocol=tcp dst-port=1373
5 ;;; cichlid
chain=virus action=drop protocol=tcp dst-port=1377
6 ;;; Worm
chain=virus action=drop protocol=tcp dst-port=1433-1434
7 ;;; Bagle Virus
chain=virus action=drop protocol=tcp dst-port=2745
8 ;;; Drop Dumaru.Y
chain=virus action=drop protocol=tcp dst-port=2283
9 ;;; Drop Beagle
chain=virus action=drop protocol=tcp dst-port=2535
10 ;;; Drop Beagle.C-K
11 ;;; Drop MyDoom
chain=virus action=drop protocol=tcp dst-port=3127-3128
12 ;;; Drop Backdoor OptixPro
chain=virus action=drop protocol=tcp dst-port=3410
13 ;;; Worm
chain=virus action=drop protocol=tcp dst-port=4444
14 ;;; Worm
chain=virus action=drop protocol=udp dst-port=4444
15 ;;; Drop Sasser
chain=virus action=drop protocol=tcp dst-port=5554
16 ;;; Drop Beagle.B
chain=virus action=drop protocol=tcp dst-port=8866
17 chain=virus action=accept protocol=tcp dst-port=9898
18 ;;; ::::Block P2P
chain=forward action=drop p2p=all-p2p
bellow my IP route :
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 ADS 0.0.0.0/0 reachable 84.235.124.5 1 pppoe-out1
1 ADC 10.1.1.0/24 10.1.1.1 0 ether2
2 ADC 84.235.124.5/32 94.97.215.73 0 pppoe-out1
Finally my Nat configuration as bellow :
[admin@MikroTik] > /ip firewall nat print
1 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=10.1.1.0/24
i hope the information i listed above its enough to get the help …
Masquerade only traffic that leaves the router via public interface
Also if you want others (not on your local network) to connect to CS server, you have to forward ports.
sorry i’m a new in Mikrotik do i remove the masquerade ?
now in the local how i can connect to CS server ? since i can’t see any one in the network ..!
in Counter Strike console (by ‘~’),
/connect IP_address_of_the_CS_server
for discovery to work, all computers need to be in one broadcast segment
I need To open ports for cs 1.6
local ip: 192.168.203.27
public ip: 203.202.242.165
Help needed
