I just really don't know what to do at this point. My topology is:
RB5009 edge router
- ether1 - WAN
- ether2 - down link to CRS312 ether1
- ether3 - down link to CRS328 ether1
- ether4 - pi-hole
- ether5 - home assistant
- ether8 - laptop dock
CRS312
- ether1 - uplink to rb5009 ether2
- ether4 - printer
- ether5- nvr
- ether7 - nas
CRS328
- ether1 - uplink to RB5009 ether3
- ether4 - poe cap AX ether1
- ether6 - poe cap AX ether1
- ether8 - poe cap AX ether1
First consultant got me up and running, but did it the old school way. Vlans on separate interfaces with separate bridges. It works, but now that I added two additional cap AXs to the house, I'm running into problems with the vlan2000 SSIDs losing internet, and I have to restart the ap for it to work.
Config for RB5009 below.
# 2026-06-16 12:25:50 by RouterOS 7.21.4
# software id = C86P-TNCF
# model = RB5009UG+S+
# serial number = HJ30A275Y8W
add name=IOT.BRIDGE
add name=LAB.BRIDGE
add admin-mac=F4:1E:57:C1:68:E7 auto-mac=no name=LOCAL.BRIDGE
add name=MANAGEMENT.BRIDGE
set [ find default-name=ether1 ] comment="WAN[ATT]" l2mtu=1514
set [ find default-name=ether2 ] comment=CRS312.NON-POE.SW l2mtu=1514
set [ find default-name=ether3 ] comment=CRS328.POE.SW l2mtu=1514
set [ find default-name=ether4 ] comment=PI-HOLE.RASPI l2mtu=1514
set [ find default-name=ether5 ] comment=HOME.ASSISTANT l2mtu=1514
set [ find default-name=ether6 ] l2mtu=1514
set [ find default-name=ether7 ] l2mtu=1514
set [ find default-name=ether8 ] l2mtu=1514
set [ find default-name=sfp-sfpplus1 ] disabled=yes l2mtu=1514
/interface wireguard
add comment=BTH-VPN listen-port=31135 mtu=1420 name=back-to-home-vpn
/interface vlan
add comment=IOT.VLAN interface=ether2 name=ether2-VLAN2000 vlan-id=2000
add comment=LAB.VLAN interface=ether2 name=ether2-VLAN3000 vlan-id=3000
add comment=MANAGEMENT.VLAN interface=ether2 name=ether2-VLAN4000 vlan-id=4000
add comment=IOT.VLAN interface=ether3 name=ether3-VLAN2000 vlan-id=2000
add comment=LAB.VLAN interface=ether3 name=ether3-VLAN3000 vlan-id=3000
add comment=MANAGEMENT.VLAN interface=ether3 name=ether3-VLAN4000 vlan-id=4000
add name=WAN
/interface wifi channel
add band=2ghz-ax disabled=no name=2.4ghz width=20mhz
add band=5ghz-ax disabled=no name=5ghz width=20/40/80mhz
/interface wifi datapath
add bridge=LOCAL.BRIDGE disabled=no name=2.4ghz vlan-id=2000
add bridge=LOCAL.BRIDGE disabled=no name=5ghz vlan-id=2000
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=2.4ghz
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=5ghz
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=ADMIN-SSID
/interface wifi configuration
add channel=2.4ghz disabled=no mode=ap name=2.4ghz security=2.4ghz ssid=2.4ghz
add channel=5ghz disabled=no mode=ap name=5ghz security=5ghz ssid=5ghz
add disabled=no mode=ap name=2.4ghz-ADMIN security=ADMIN-SSID ssid=REDACTED
add disabled=no mode=ap name=5ghz-ADMIN security=ADMIN-SSID ssid=REDACTED
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add name=dhcp_pool2 ranges=192.168.101.2-192.168.101.254
add name=dhcp_pool3 ranges=192.168.102.2-192.168.102.254
add name=dhcp_pool4 ranges=192.168.103.2-192.168.103.254
add address-pool=dhcp_pool1 interface=LOCAL.BRIDGE name=dhcp1
add address-pool=dhcp_pool2 interface=IOT.BRIDGE name=dhcp2
add address-pool=dhcp_pool3 interface=LAB.BRIDGE name=dhcp3
add address-pool=dhcp_pool4 interface=MANAGEMENT.BRIDGE name=dhcp4
/disk settings
set auto-media-interface=LOCAL.BRIDGE auto-media-sharing=yes auto-smb-sharing=yes
add bridge=LOCAL.BRIDGE interface=ether2
add bridge=LOCAL.BRIDGE interface=ether3
add bridge=LOCAL.BRIDGE interface=ether4
add bridge=LOCAL.BRIDGE interface=ether5
add bridge=LOCAL.BRIDGE interface=ether6
add bridge=LOCAL.BRIDGE interface=ether7
add bridge=LOCAL.BRIDGE interface=ether8
add bridge=LOCAL.BRIDGE interface=sfp-sfpplus1
add bridge=MANAGEMENT.BRIDGE interface=ether2-VLAN4000
add bridge=IOT.BRIDGE interface=ether3-VLAN2000
add bridge=LAB.BRIDGE interface=ether3-VLAN3000
add bridge=MANAGEMENT.BRIDGE interface=ether3-VLAN4000
add bridge=IOT.BRIDGE interface=ether2-VLAN2000
set discover-interface-list=all
add interface=ether1 list=WAN
/interface wifi capsman
set enabled=yes interfaces=MANAGEMENT.BRIDGE
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=2.4ghz-ADMIN slave-configurations=2.4ghz supported-bands=\
2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=5ghz-ADMIN slave-configurations=5ghz supported-bands=5ghz-ax
add address=192.168.100.1/24 comment=LAN.ADMIN interface=LOCAL.BRIDGE network=192.168.100.0
add address=192.168.101.1/24 comment=IOT.GATEWAY interface=IOT.BRIDGE network=192.168.101.0
add address=192.168.102.1/24 comment=LAB.GATEWAY interface=LAB.BRIDGE network=192.168.102.0
add address=192.168.103.1/24 comment=MANAGEMENT.GATEWAY interface=MANAGEMENT.BRIDGE network=192.168.103.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes ddns-update-interval=10m
/ip cloud back-to-home-user
add allow-lan=yes file-access=full file-access-path="/BTH Files" name=Thinkpad.X1 public-key=\
"REDACTED"
add allow-lan=yes file-access=full file-access-path="/BTH Files" name=Thinkpad.X1.Linux public-key=\
"REDACTED"
/ip dhcp-client
add comment=ATT.FIBER.WAN default-route-tables=main interface=ether1 use-peer-dns=no
add address=192.168.100.0/24 dns-server=192.168.100.250,1.1.1.1,8.8.8.8 gateway=192.168.100.1
add address=192.168.101.0/24 dns-server=192.168.100.250,1.1.1.1,8.8.8.8 gateway=192.168.101.1
add address=192.168.102.0/24 dns-server=192.168.100.250,1.1.1.1,8.8.8.8 gateway=192.168.102.1
add address=192.168.103.0/24 dns-server=192.168.100.250,1.1.1.1,8.8.8.8 gateway=192.168.103.1
set allow-remote-requests=yes servers=192.168.100.250,1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.35.0/24 disabled=yes list=management.addresses
add address=192.168.100.0/24 list=management.addresses
add address=192.168.216.0/24 list=management.addresses
add action=accept chain=input comment="Permit: Established, related, and untracked input traffic." connection-state=\
established,related,untracked
add action=drop chain=input comment="Drop: Invalid input traffic." connection-state=invalid
add action=accept chain=input comment="Permit: ICMP input traffic." protocol=icmp
add action=accept chain=input comment="Permit: BGP input traffic." dst-port=179 protocol=tcp
add action=accept chain=input comment="Permit: OSPF input traffic from list backbone.interfaces." in-interface-list=WAN \
protocol=ospf
add action=accept chain=input comment="Permit: Input traffic from list management.addresses" src-address-list=\
add action=accept chain=input comment="Permit: BFD input traffic from backbone.interfaces." dst-port=3784 in-interface-list=WAN \
protocol=udp
add action=accept chain=input comment="Permit: Bandwidth test server input traffic." dst-port=2000 protocol=tcp
add action=drop chain=input comment="Drop: All other input traffic."
add action=accept chain=forward comment="ACCEPT: ESTABLISHED AND RELATED" connection-state=established,related
add action=accept chain=forward comment="ACCEPT: ADMIN TO SUBNETS" disabled=yes src-address-list=management.addresses
add action=accept chain=forward comment="ACCEPT: OUT TO PIHOLE" dst-address=192.168.100.250
add action=accept chain=forward comment="ACCEPT: ADMIN TO IOT" dst-address=192.168.101.0/24 src-address=192.168.100.0/24
add action=accept chain=forward comment="ACCEPT: MGMT VLAN TO IOT" dst-address=192.168.101.0/24 src-address=192.168.103.0/24
add action=accept chain=forward comment="ACCEPT: ADMIN TO LAB" dst-address=192.168.102.0/24 src-address=192.168.100.0/24
add action=accept chain=forward comment="ACCEPT: MGMT VLAN TO LAB" dst-address=192.168.102.0/24 src-address=192.168.103.0/24
add action=accept chain=forward comment="ACCEPT: OUT TOWARDS INTERNET" out-interface-list=WAN
add action=drop chain=forward comment="DROP: IOT TO ADMIN" dst-address=192.168.100.0/24 src-address=192.168.101.0/24
add action=drop chain=forward comment="DROP: IOT TO MGMT VLAN" dst-address=192.168.103.0/24 src-address=192.168.101.0/24
add action=drop chain=forward comment="DROP: IOT TO LAB" dst-address=192.168.102.0/24 src-address=192.168.101.0/24
add action=drop chain=forward comment="DROP: EVERYTHING ELSE"
add action=masquerade chain=srcnat comment="GENERAL INTERNET MASQ" out-interface=ether1
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=\
fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!*2000011
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!*2000011
/system clock
set time-zone-name=America/Chicago
/system identity
set name=EDGE.RTR
/system package update
set channel=long-term
/tool mac-server
set allowed-interface-list=*2000011
/tool mac-server mac-winbox
/tool romon
set enabled=yes
cap AX config (I added reboots to fix the dropping issue for now)
# 2026-06-16 12:27:17 by RouterOS 7.21.4
# software id = G20U-MQYJ
# model = cAPGi-5HaxD2HaxD
# serial number = HGZ0ABNW12N
add name=LOCAL.BRIDGE vlan-filtering=yes
/interface wifi
# managed by CAPsMAN F4:1E:57:C1:68:E7%LOCAL.BRIDGE-VLAN4000, traffic processing on CAP
# mode: AP, SSID: REDACTED, channel: 5885/ax/eeeC
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap disabled=no \
security.authentication-types="" .ft=yes
# mode: AP, SSID: REDACTED, channel: 2462/ax/eC
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap disabled=no \
/interface vlan
add interface=LOCAL.BRIDGE name=LOCAL.BRIDGE-VLAN4000 vlan-id=4000
/interface ethernet switch
set 0 cpu-flow-control=yes
add bridge=LOCAL.BRIDGE interface=wifi2
add bridge=LOCAL.BRIDGE interface=wifi1
add bridge=LOCAL.BRIDGE interface=ether1
add bridge=LOCAL.BRIDGE interface=wifi3 pvid=2000
add bridge=LOCAL.BRIDGE interface=wifi4 pvid=2000
/interface bridge vlan
add bridge=LOCAL.BRIDGE tagged=LOCAL.BRIDGE,ether1 vlan-ids=4000
add bridge=LOCAL.BRIDGE tagged=LOCAL.BRIDGE,ether1 untagged=wifi3,wifi4 vlan-ids=2000
/interface wifi cap
set discovery-interfaces=LOCAL.BRIDGE-VLAN4000 enabled=yes
/ip dhcp-client
add default-route-tables=main interface=LOCAL.BRIDGE-VLAN4000 use-peer-dns=no
set servers=1.1.1.1,8.8.8.8
/ip service
set api disabled=yes
set api-ssl disabled=yes
/system clock
/system identity
set name="cAP 1"
/system scheduler
add interval=1d name=reboot-caps on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2026-06-14 \
start-time=04:00:00
add interval=2h name=auto-reboot on-event="/system reboot" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-time=startup
/tool romon
set enabled=yes
I had a second consultant write a new config using current vlan best practices on a single bridge, and regardless if I start from a default config or a totally blank slate with no config, it doesn't work. I either lose internet, lose access to winbox, or both.
RB5009 config2 below
add name=LOCAL.BRIDGE vlan-filtering=no
/interface vlan
add interface=LOCAL.BRIDGE name=VLAN2000-IOT vlan-id=2000
add interface=LOCAL.BRIDGE name=VLAN3000-GUEST vlan-id=3000
add interface=LOCAL.BRIDGE name=VLAN4000-MGMT vlan-id=4000
add name=WAN
add name=LAN
add name=ISOLATED_VLANS
add name=MGMT
add name=PIHOLE_ACCESS
add interface=LOCAL.BRIDGE list=LAN
add interface=LOCAL.BRIDGE list=PIHOLE_ACCESS
add interface=VLAN2000-IOT list=ISOLATED_VLANS
add interface=VLAN2000-IOT list=PIHOLE_ACCESS
add interface=VLAN3000-GUEST list=ISOLATED_VLANS
add interface=VLAN4000-MGMT list=MGMT
add interface=VLAN4000-MGMT list=PIHOLE_ACCESS
add address=192.168.10.1/24 interface=LOCAL.BRIDGE network=192.168.10.0
add address=192.168.20.1/24 interface=VLAN2000-IOT network=192.168.20.0
add address=192.168.30.1/24 interface=VLAN3000-GUEST network=192.168.30.0
add address=192.168.40.1/24 interface=VLAN4000-MGMT network=192.168.40.0
add name=POOL-TRUSTED ranges=192.168.10.100-192.168.10.200
add name=POOL-IOT ranges=192.168.20.100-192.168.20.200
add name=POOL-GUEST ranges=192.168.30.100-192.168.30.200
add name=POOL-MGMT ranges=192.168.40.100-192.168.40.240
add address-pool=POOL-TRUSTED interface=LOCAL.BRIDGE name=DHCP-TRUSTED
add address-pool=POOL-IOT interface=VLAN2000-IOT name=DHCP-IOT
add address-pool=POOL-GUEST interface=VLAN3000-GUEST name=DHCP-GUEST
add address-pool=POOL-MGMT interface=VLAN4000-MGMT name=DHCP-MGMT
add address=192.168.10.0/24 dns-server=192.168.40.250 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.40.250 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.30.1
add address=192.168.40.0/24 dns-server=192.168.40.250 gateway=192.168.40.1
/ip dhcp-server lease
add address=192.168.40.254 mac-address=D4:01:C3:70:7A:98 server=DHCP-MGMT comment="CRS312"
add address=192.168.40.253 mac-address=F4:1E:57:B2:B1:F3 server=DHCP-MGMT comment="CRS328"
add address=192.168.40.252 mac-address=F4:1E:57:32:60:13 server=DHCP-MGMT comment="CAP.1"
add address=192.168.40.251 mac-address=F4:1E:57:32:5F:AD server=DHCP-MGMT comment="CAP.2"
add address=192.168.40.250 mac-address=F4:1E:57:32:62:A3 server=DHCP-MGMT comment="CAP.3"
add bridge=LOCAL.BRIDGE interface=ether2 frame-types=admit-all ingress-filtering=yes comment="TRUNK to CRS312 (Hybrid)"
add bridge=LOCAL.BRIDGE interface=ether3 frame-types=admit-all ingress-filtering=yes comment="TRUNK to CRS328 (Hybrid)"
add bridge=LOCAL.BRIDGE interface=ether4 pvid=4000 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="ACCESS: Pi-Hole"
add bridge=LOCAL.BRIDGE interface=ether5 pvid=4000 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="ACCESS: Home Assistant"
add bridge=LOCAL.BRIDGE interface=ether8 pvid=1 frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes comment="ACCESS: Laptop Docking"
add bridge=LOCAL.BRIDGE tagged=LOCAL.BRIDGE,ether2,ether3 untagged=ether8 vlan-ids=1
add bridge=LOCAL.BRIDGE tagged=LOCAL.BRIDGE,ether2,ether3 vlan-ids=2000
add bridge=LOCAL.BRIDGE tagged=LOCAL.BRIDGE,ether2,ether3 vlan-ids=3000
add bridge=LOCAL.BRIDGE tagged=LOCAL.BRIDGE,ether2,ether3 untagged=ether4,ether5 vlan-ids=4000
add name=DP-TRUSTED bridge=LOCAL.BRIDGE
add name=DP-IOT bridge=LOCAL.BRIDGE vlan-id=2000
add name=DP-GUEST bridge=LOCAL.BRIDGE vlan-id=3000 client-isolation=yes
add name=SEC-TRUSTED authentication-types=wpa2-psk,wpa3-psk passphrase="YourTrustedPassword" ft=yes ft-over-ds=yes
add name=SEC-IOT authentication-types=wpa2-psk passphrase="YourIoTPassword"
add name=SEC-GUEST authentication-types=wpa2-psk,wpa3-psk passphrase="YourGuestPassword"
add name=CFG-TRUSTED ssid=REDACTED security=SEC-TRUSTED datapath=DP-TRUSTED mode=ap
add name=CFG-IOT ssid=2.4ghz security=SEC-IOT datapath=DP-IOT mode=ap
add name=CFG-GUEST ssid=GUESTS.WIFI security=SEC-GUEST datapath=DP-GUEST mode=ap
add action=create-dynamic-enabled master-configuration=CFG-TRUSTED slave-configurations=CFG-IOT,CFG-GUEST supported-bands=5ghz-ax
add action=create-dynamic-enabled master-configuration=CFG-TRUSTED slave-configurations=CFG-IOT,CFG-GUEST supported-bands=2ghz-ax
set enabled=yes interfaces=VLAN4000-MGMT,LOCAL.BRIDGE
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input in-interface-list=MGMT comment="Admin access"
add action=drop chain=input in-interface-list=WAN comment="Drop WAN to Router"
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward in-interface-list=MGMT comment="MGMT can reach anywhere"
add action=accept chain=forward in-interface=LOCAL.BRIDGE out-interface=VLAN2000-IOT comment="Trusted can manage IoT only"
add action=accept chain=forward in-interface-list=PIHOLE_ACCESS dst-address=192.168.40.250 protocol=udp dst-port=53 comment="Allow DNS UDP to Pi-Hole"
add action=accept chain=forward in-interface-list=PIHOLE_ACCESS dst-address=192.168.40.250 protocol=tcp dst-port=53 comment="Allow DNS TCP to Pi-Hole"
add action=accept chain=forward in-interface-list=PIHOLE_ACCESS dst-address=192.168.40.250 protocol=icmp comment="Allow Ping to Pi-Hole"
add action=accept chain=forward in-interface-list=ISOLATED_VLANS out-interface-list=WAN comment="IoT and Guest to Internet"
add action=drop chain=forward in-interface-list=ISOLATED_VLANS out-interface-list=!WAN comment="Isolate IoT and Guest entirely"
/interface bridge set LOCAL.BRIDGE vlan-filtering=yes
I really don't know what to do at this point. I can't spend anymore money on consulting, and chatgpt using the steering guidance to the mikrotik documentation isn't getting it done. Same issues, my internet or access to winbox keeps breaking once filtering is turned on.
