Can CPE’s be configured on failure of primary AP to auto connect to another AP,
n21roadie
n21roadie
One solution is to have two accesspoint with the same ssid and same security profile.
If one AP fail, the cpe automatically search another AP.
The two AP must have frequency inside the scan list of the CPE.
There is a warning:
if a cpe have a good signal to first AP and a bad signal to second AP, you cannot control where the cpe is connected, unless you play with connect/access lists.
