CPE Badge / Logo where to get them
Anybody know where I can get Logo transfers made up for sticking on CPE’s and Antenna’s ? somewhere in europe
please clarify what sticker you mean. maybe an example?
I want to put my Company Logo on the front Of CPE’s and Antennas.
order some sticker from any sticker shop in your city :slight_smile: there are probably many companies who will make custom stickers
like this http://www.zazzle.es or similar
I suggest to find anything for outdoor use, because standard stickers would be stuck untill the first rain fell :slight_smile:
Definitely Need something designed for outdoor use, I was just wondering if anybody had found something that is suitable but not expensive
a Distributor in Germany can this make
http://shop.meconet.de/Hardware-component-parts/Mainboards/MikroTik/Integrated-solutions/Your-Logo-on-RB-2x0-RB-75x-or-RB-95x::115724.html?language=en
Nice, but I suspect it’s for indoor use.
In our production we considered some stickers, but finally decided to make plastic logo formed by the injection mould form, see here → http://www.wireless-instruments.com/en/produkty/33/43/wibox-enclosures/wibox-medium/wibox-medium.html . We use stickers only on the back side for the serial number and antenna model info.
With stickers remember also about exposition for the sun, not only about a good glue. I saw a lot of beauty stickers cracked from the UV radiation.
If you want to spend a bit more money and have a good effect think about 3D sticker (convex I mean).
For outdoor use, you need other material for the sticker. For our outdoor products we use 0.25mm polycarbonate film, with 3M glue.
We use vinyl stickers on all out external equipment. Any good printer should be able to offer a vinyl, external sticker on self adhesive backing.
This is who we used in the UK : http://www.harrisscreenprint.co.uk/
I don’t know about EU, but in the US, people put clear stickers in their car’s back window to advertise their alma mater. We had some made up for our equipment. I guess you’d call them custom college decals or something. They came on a roll of 500 or some large number like that.
