Cpe Configuration
I need to know how to configure a cpe with RB 411.
This is my network:
VPN (PPPoE) concentrator
Access Point
CPE
CPE has to be configured as a client bridge.
Thanks in advance.
Levis
Read the manual
There’s nothing worse that a forum member always saying READ THE MANUAL DUDE!
Cmon. This is supposed to be a community for help, not an elitist club.
A more appropriate (and appreciated) response might be…
“This is too vague a question and would require a detailed and all inclusive answer. Perhaps you can make an attempt to program a CPE, and ask more specific questions after your attempt.”
There is a reason why you have “newbie” under your forum name.
If all your post are like the one above. Well, you know what you are.
Thanks DesertTek,
I’ ll try to configure by myself and I’ll post more detailed questions.
Thanks again :wink:
Levis
As long as your PPPoE concentrator is on the same bridge as your AP you should be good. Set your CPE card to “station” mode. Setup a PPPoE client on your wlan1 with the proper username/password settings. Setup DHCP server on your ethernet. Setup NATing in your firewall rules.
Eric
I created a bridge and assigned wlan1 and ethernet interfaces to it.
Wlan1 in station mode without pppoe client: a router beside the cpe will be my pppoe client.
I 'll try so.
Thanks,
levis
