Hi. I have Groove A52 device with default settings from Quick Set and configured as CPE device. I can select the desirable hotspot to connect, enter the password and connect successfully from Winbox. But when i try to connect to access point from the browser (i have tried chrome, IE, safari on ios, default browser and chrome on android smartphone) - it fails. It looks like i can choose the access point on quick config screen, then i can see it the Network Name propagated with the correct network, i can enter the password. But after i press Connect - i can see Status “Searching” and nothing happens anymore. But Groove connects to the remote network from Winbox without any problem.
Groove uses default config (every configuration is done from Quick Set screen) and updated to the latest firmware update (6.38.1). I use Windows 10 with latest updates, Chrome is also updated.
It seams like Security Profile is not updated when connecting from the browser from Quick Set windows (mode remains as none, and perhaps password is blank).
