CPE setup
Trying to set up my first mikrotik AP and CPE. I have used mostly UBNT products for this until now but would like to try MT on a new tower. Here is my problem. Set up AP as bridge and connect the cpe . Wireless connection is good but no data. CPE is set up as a station and is set as a router. If I bridge ether 1 and wan 1, I get data. But as soon as i go back to routing either 1 i lose the data. While as a router dhcp is issuing fine. I am using a rb411 for CPE. Can anyone give my some pointers on where to start, or recommend a consultant. I have tried to contact a couple but can never get our schedules to work out.
Can you can post the output from /export compact from both systems?
Thank for the offer to help but I have resolved the problem. I had used the Quickset to set the CPE up originally and could not get it to transfer data. However I finally reset the router and started over without using quickset and I now have a working link. Thank you.
