I think i have too many traffic on my Router, is it possible to switch from dynamic mss change rules to one static rule for all customer?
I will hope that the solution reduce my rx drops.
It is ROS 5.07 with AMD Quad Core and intel e1000 card
Okay no Problem, i have 900 customers with pppoe on this Router and under Profile i have enable mss change. So i have ca. 1400 dynamic rules under IP firewall mangle. And now, i want to know if it possible to switch from dynamic rules to one static to reduce the cpu?
Again - yes, probably. Post the dynamic rules the router created so we can look at them and try to summarize them in just one rule. I don’t use PPPoE. Unless you copy and paste the specific rules the router made for you I cannot help you. 3 or 4 of them will suffice.
