Good afternoon,
I have several load balancers with Mikrotik RB750 and 750G, some with versions 4.16 and others with the newest 4.17.
The problem is that sometimes and appears to be randomly the CPU goes 100% for several hours or days.
Here are some images.
I am using PCC and in some cases NTH.
Here is the configuration of mangle.
add action=mark-connection chain=input comment=“” disabled=no in-interface=wlan1 new-connection-mark=wlan1_conn passthrough=yes
add action=mark-connection chain=input comment=“” disabled=no in-interface=wlan2 new-connection-mark=wlan2_conn passthrough=yes
add action=mark-connection chain=input comment=“” disabled=no in-interface=wlan3 new-connection-mark=wlan3_conn passthrough=yes
add action=mark-connection chain=input comment=“” disabled=no in-interface=wlan4 new-connection-mark=wlan4_conn passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=wlan1_conn disabled=no new-routing-mark=to_wlan1 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=wlan2_conn disabled=no new-routing-mark=to_wlan2 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=wlan3_conn disabled=no new-routing-mark=to_wlan3 passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=wlan4_conn disabled=no new-routing-mark=to_wlan4 passthrough=yes
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wlan1_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/0
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wlan2_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/1
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wlan3_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/2
add action=mark-connection chain=prerouting comment=“” disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wlan4_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting comment=“” connection-mark=wlan1_conn disabled=no in-interface=Local new-routing-mark=to_wlan1 passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=wlan2_conn disabled=no in-interface=Local new-routing-mark=to_wlan2 passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=wlan3_conn disabled=no in-interface=Local new-routing-mark=to_wlan3 passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=wlan4_conn disabled=no in-interface=Local new-routing-mark=to_wlan4 passthrough=yes
Thanks in advance.
Regards.
