CPU 100% - roughly console 40% + management 60%
i got a RB751G-2HnD here.
not sure what’s wrong with it, CPU is 100% flat all the time, and in profile, the CPU is eaten by, roughly, console 40% and management 60%.
really strange. any idea?
i have similar proplem with wifi AP Metal 2SHPn (but on ROS 6.5)
support says there is console crashing bug
is this something that i should worry about? and is there a fix for it?
i am not sure if this is related but the box was reset with new completely configuration in less than 12 hours ago. and i noticed the very next morning that i suddenly cannot access it via winbox. strangly web access works. when i used web access to reboot, it reboots and hangs. i had to physically unplug the power to get it back again.
if 100% CPU is relating to this, then i am worried… before the configure reset, i don’t remember seeing this problem.
else, routing and openvpn works fine for me so far.
considering to export the settings and reset it again…
Try disabling snmp if you don’t need it … I’ve seen high management usage in many cases caused by enabled snmp.
JF
is this in ip/snmp? if yes, it’s not enabled.
i am a bit worried because i’d be away for a week or two. fingers crossed that nothing happens while i am away.
