cpu clock
Hi to all!
i’ve some problem with a RB532A. I set my cpu frequency at 399Mhz with Termnial → interface → routerboards → settings → set → cpu-frequency=399Mhz
and after that, keep-frequency
when i check with system resource it immediatly goes on 399 Mhz, but after few seconds or reboot it returns at 266Mhz (cpu mode works in safety mode)
how can I lock at 399Mhz??
thx :sunglasses:
  1. set frequency
  2. power off router (unplug power)
  3. power on router
  4. save frequency
it doesn’t work.
when I set frequency, if I wait or turn off/restart routerboard it automatically goes back on 266mhz.
so strange…
do it just like i described above. don’t wait for anything, and use hard reset (power off)
Can these same steps be done remotely by ‘rebooting’ instead of ‘powering off’?
no, power off is essential
