Hello, If I receive a DDoS, there is any way to limit the CPU usage for the main uplink to don’t use more than a 90% of CPU and then be available to login to the router and do the blackhole?
My upstream, can provide me a second uplink with other IP, but the main problem, is, if I’m under DDoS and the CPU is 100% the entire router is blocked and I can’t also connect to the rescue interface.
