cpu frequency problem.
hi
i can’t set frequency mode to 333mhz on rb 532
after reboot frequency is always 266
i set
/system routerboard settings set cpu-frequency=333
and it shows
baud-rate: 115200
boot-delay: 1s
boot-device: nand
enter-setup-on: any-key
cpu-mode: regular
memory-test: no
cpu-frequency: 333MHz
safe-cpu-frequency: 266MHz
boot-protocol: bootp
enable-jumper-reset: yes
and after reboot is still 266mhz
baud-rate: 115200
boot-delay: 1s
boot-device: nand
cpu-mode: regular
memory-test: no
when i do keep-frequency then allways is drop to 266mhz
any sugestions??
you should set the CPU to 333Mhz, then shut it down. Take the power out and plug it back in. After that you can use keep-cpu-frequency.
no
:slight_smile:
i think there is problem when i use terminal via winbox
when i set via telnet or ssh all is ok
i think there is problem with winbox …
now i try set scheduler via telnet
maybe also it will work
I did it via winbox terminal and it works fine. You do have to pull the power, if it reboots without power-down it will come back up at 266
Was running 2.9.1
Regards
