cpu full of and memoy full of 6.36
hi
i work in CCR1016 12g the cpu and memory is full off and and the dude client 6.36 is Stops after that the CCR1016 is reboot and work half an hour and reboot >> what I do to to solve
this issues pic to show the full off cpu and memory >> Sorry about my english :confused:
http://www.up-00.com/
Please proceed as follows:
  • Reboot dude server host.
  • Generate supout file #1.
  • Let the system run for a while, when most of ram has been consumed again then generate supout file #2.
After you have both supout files send them to support@mikrotik.com We will check what caused the memory leak.
memory full off
http://www.up-00.com/firewall raw
after reboot and disable the dude server
and the seam problem
Screenshots does not tell us much. If there is an memory leak we would like to fix it. IF you still intend to use The Dude server on that CCR of yours.
Same issue, version 6.36 on an x86 virtualized server (Xen). Starting with 1GB RAM, shrinking free memory accross the time until it reboots.
Increased RAM size only extends online time, but reboots anyway.
Thanks. Sorry for my english.
