Cpu load problem
Hi !
Have some problem on multicore x86 system (double XEON 5520, 400 mbit, 60kpps, routerOS 5rc4).
Here is the graph, CPU load cant increase over 33 %.
At the moments of the greatest loading, the one of core have 100% load, over cores from 0% to 20 %,icmp time goes from 1 ms to 60 ms.
Looks like RPS is working not correctly.
Help plz.
 /system resource> print
                   uptime: 6d2h51m54s
                  version: "5.0rc4"
              free-memory: 811376KiB
             total-memory: 1943128KiB
                      cpu: "Intel(R)"
                cpu-count: 8
            cpu-frequency: 2527MHz
                 cpu-load: 23%
           free-hdd-space: 240133380KiB
          total-hdd-space: 240348676KiB
  write-sect-since-reboot: 10875170
         write-sect-total: 10875170
        architecture-name: "x86"
               board-name: "x86"
                 platform: "MikroTik"
One of 8 cores have 100 % load randomly.
/system resource cpu> print
CPU LOAD        IRQ         DISK
0   11%         11%         0%
1   2%          1%          0%
2   6%          6%          0%
3   100%        99%         0%
4   8%          8%          0%
5   15%         14%         0%
6   14%         14%         0%
7   16%         15%         0%
CPU LOAD        IRQ         DISK
0   6%          6%          0%
1   7%          7%          0%
2   5%          5%          0%
3   15%         14%         0%
4   3%          3%          0%
5   10%         10%         0%
6   14%         14%         0%
7   100%        99%         0%
any ideas ?
seems, that IRQs for the traffic are really taking the gut out of CPU.
actually, i’ve seen exactly the same on older (less multicore) systems. you could never get much more than one core loaded fully, and some other routine on other core(-s).
however, muliple cores/cpus really let MT get around while under heavy load - since migratied to multicore, the router has never locked up or got unaccessible, while under any load.
You consider that the only thing that it is possible to make it to update the hardware ?
try rc7…kernel is updated.
its rc7 now… no changes… :frowning:
I have established distribution IRQ on processors manually.
now :
/system resource irq> print
 # IRQ USERS        CPU        ACTIVE-CPU COUNT
 0 4   serial        0          0          1
 1 9   acpi        0          0          1
 2 14  ide0        0          0          0
 3 15  ide1        0          0          0
 4 16  usb8        0          0          0
       usb7
       usb6
       usb2
 5 18  ata_piix        0          0          38800
 6 19  usb5        0          0          43
       usb4
       usb3
       usb1
 7 21  ata_piix        0          0          0
 8 64  aerdrv        0          0          0
 9 65  aerdrv        0          0          0
10 66  aerdrv        0          0          0
11 67  aerdrv        0          0          0
12 68  aerdrv        0          0          0
13 72  ZSTTK        5          5          1
14 73  eth0-rx-0        6          6          47650
15 74  eth0-rx-1        6          6          85001
16 75  eth0-rx-2        4          4          89491
17 76  eth0-rx-3        4          4          38383
18 77  eth0-tx-0        6          6          14761
19 78  eth0-tx-1        6          6          92847
20 79  eth0-tx-2        6          6          40306
21 80  eth0-tx-3        6          6          12898
22 81  ether1        0          0          1
23 82  eth1-rx-0        3          3          2703
24 83  eth1-rx-1        3          3          59958
25 84  eth1-rx-2        3          3          54213
26 85  eth1-rx-3        3          3          82855
27 86  eth1-tx-0        3          3          13310
28 87  eth1-tx-1        3          3          84819
29 88  eth1-tx-2        3          3          7723
30 89  eth1-tx-3        0          0          15200
31 90  ether2        7          7          1
32 91  eth2-TxRx-0        5          5          62201
33 92  eth2-TxRx-1        5          5          1033
34 93  eth2-TxRx-2        2          2          53675
35 94  eth2-TxRx-3        2          2          37372
36 95  eth2-TxRx-4        7          7          13043
37 96  eth2-TxRx-5        0          0          8368
38 97  eth2-TxRx-6        1          1          33405
39 98  eth2-TxRx-7        7          7          31029
40 99  KES        6          6          1
41 100 eth3-TxRx-0        1          1          39321
42 101 eth3-TxRx-1        1          1          95870
43 102 eth3-TxRx-2        0          0          71221
44 103 eth3-TxRx-3        1          1          57424
45 104 eth3-TxRx-4        3          3          7635
46 105 eth3-TxRx-5        3          3          52672
RPS is disabled on all int.
Kernels are loaded proportionally, until then while on the interface doesn’t appear more 50k pps.
I am stuck with the same problem . Posted another thread but no help. How do we improve the throughput on the router ? I am not running the latest 5.4 upgraded from using 5.0rc4 but that has not made a difference
