Hello.
Today i founded that on my Routerboard 2011uas-2hnd-in CPU loads 100%.
[admin@MikroTik] /ip dns> print
servers:
dynamic-servers: 212.75.210.62,212.75.211.2
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 143KiB
[admin@MikroTik] > /tool profile
NAME CPU USAGE
firewall-mgmt all 0.5%
wireless all 0.5%
ethernet all 4.5%
console all 0.5%
dns all 82%
traffic-flow all 0%
firewall all 1%
networking all 0.5%
winbox all 1%
logging all 0%
management all 8.5%
bridging all 0%
unclassified all 1%
How solved my problem?
Best regards, Dmitriy/
Secure the DNS server on your router.
Configure your firewall input chain correctly.
tomaskir
May be you can help me with this?
Google says me that spell
chain=input action=drop protocol=udp dst-port=53
but after this rule Internet down
Do something like this:
add chain=input comment="Input chain" connection-state=established
add chain=input connection-state=related
add chain=input connection-state=invalid action=drop
add chain=input protocol=icmp
add chain=input dst-port=8291 protocol=tcp
add chain=input in-interface="LAN Interface Name"
add action=log chain=input disabled=yes log-prefix=Drop
add action=drop chain=input
Replace the LAN interface name according to your needs.
Don’t use such rule, you are blocking all traffic to port 53 and thus blocking DNS. Just limit queries to your local LAN address range:
chain=input action=drop protocol=udp dst-port=53 src-address=!10.10.10.0/24
Replace “10.10.10.0/24” with your local LAN range
i modify last rule
chain=input action=drop protocol=udp in-interface=ether1-gateway dst-port=53
and that help me down CPU to 10-20%
But now i see that http://d.pr/i/2FQu It’s not dangerous for my RB? What does mean this statistic http://d.pr/i/XEQZ ?
You got attacked with a DNS amplification atack, because your router was not properly firewalled.
The counter on that rule is so high, because the attack is still in progress, but the firewall is blocking it.
tomaskir:
LAN interface = WAN? If yes, after this rules my internet is down
LAN interface is your Local Area Network interface.
The interface where your clients connect on, NOT the internet interface.
That firewall blocks all communication from everywhere, except the LAN interface specified, connections are allowed there.
Post “/interface export compact” and I will modify it according to your needs.
tomaskir:
[admin@MikroTik] > /interface export compact
# aug/01/2013 20:19:18 by RouterOS 6.1
# software id = 2WQI-40PS
add admin-mac=%secret mac% auto-mac=no l2mtu=1598 name=bridge-local protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above country=russia disabled=no distance=indoors \
ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge wireless-protocol=802.11
set 0 name=ether1-gateway
set 5 name=ether6-master-local
set 6 master-port=ether6-master-local name=ether7-slave-local
set 7 master-port=ether6-master-local name=ether8-slave-local
set 8 master-port=ether6-master-local name=ether9-slave-local
set 9 master-port=ether6-master-local name=ether10-slave-local
set 10 name=sfp1-gateway speed=100Mbps
set [ find default=yes ] authentication-types=gpe mode=dynamic-keys wpa-pre-shared-key=%secret key%\
gper-shared-key=%secret key%
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=wlan1
I use ether1-ether5. Where:
ether1 -Internet cable from my ISP
ether2-ether5 - Local
ether6-ether10 - empty
Proper firewall:
add chain=input in-interface=bridge-local
tomaskir
Thanks a lot.
Can you tell me, what mean this rule
How i understand, that rule log something or something else?
Its a rule that logs all the dropped traffic into the log. Its disabled, I enable it if I need to test things.
You can read more about all of this on http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Filter
My RB450G got DNS attack today.
This topic is very useful and it work for me.
Thank you very much for sharing.
its works perfectly in CCR -1036.
