i have ddos protection with mikrotik and am using my dedicated server as the firewall with mikrotik what i want ask what is the best for the anti ddos alot of cores or high clock speed of the cores so what i want to say what is better than for me amd epic or i9-900k
any help
So I do not perhaps understand the question fully but if we compare AMD Epyc and Intel I9 I would say that Intel is better depending on workload.
AMD still have more CPU latency due to their architecture and that is most lightly a benefit in network operation but that is also down to load and what you are doaing.
AMD Epyc scales to 64 cores and can provdie a heck of a lot more performance then a I9 but and I9 can be better at a single thread type applicaition.
So per usual I would say it deepens on what you intend to do and how the workload looks.
But that’s exactly the essence of the OP’s question, how does Mikrotik firewall (OK, linux netfilter) spread the network traffic processing among multiple cores. Given that it does spread it, I’d definitely prefer more cores with slightly less clock rate to higher clock rate but less cores. However, there is also the issue of the available bandwidth to the RAM (the CPU needs to inspect the packets’ headers to decide what to do with them), so this is a third factor to consider.
am using anti ddos system on the mikrotik os to filter some of ddos types so i got alot of packets and the mikrotik check if its normal client or its attack my english not very good to say what am doing on this firewall but i already type small example am getting alot of attacks with
see how many packets they send with there attacks so this is what i want to know
much per core performance or much cores
