CPU stress test
Hi all,
Is there a manual way to stress the CPU to 100% load? I want to try some thermal solutions for high load scenarios. I’m using a RB4011iGS+
Thanks in advance
Disable STP and create some ethernet-loops ? That will get the fire going :wink:
Thank you very much for the reply! I tried that with 3 loops and almost did the trick. The thing is that it maxes out cores 1, 2 and 3 but core 0 sits idle and the overall usage is 75%
RoS might use a Linux capability called cgroups (control groups) to protect the admin kernel from someone over using the cpu.
I guess it takes 4 loops to max-out 4 cores.
