cpu usage = 100
HI all
i am facing problem with the cpu usage . when the traffic goes high . the cpu usage become 100 percents and packet drop . my mikrotic is 2.9.27 n is used for BGP + static route . It use for 10mbps connection .
the users are having p2p , and many other applications . can i do anything on Mikrotic to improve ?or how to troubleshoot
my hardware spec intel xeon 3.06
ram 1gb . ( the ram used up just 200+ mbps )
sounds like you need to upgrade to 2.9.51
bgp on 2.9.27 is very buggy (unusable really). you can upgrade for free.
