CPU usage is high around 300Mbs
We are running.
CRS510-8XS-2XQ.
Around 300Mbps traffic we see high CPU usage.
Firewall config is as below with fasttrack enabled, am I doning something wrong here and fasttrack is not working fully?
Any guidance will be appreciated.
add action=fasttrack-connection chain=forward connection-nat-state=srcnat connection-state=established,related hw-offload=no
add action=accept chain=input dst-address=10.105.85.0/24 src-address=10.255.11.0/24
add action=accept chain=input dst-address=10.100.85.0/24 src-address=10.255.11.0/24
add action=accept chain=forward dst-address=10.255.11.0/24 src-address=10.100.85.0/24
add action=accept chain=forward dst-address=10.255.11.0/24 src-address=10.105.85.0/24
add action=accept chain=forward connection-state=established,related disabled=yes
add action=accept chain=forward comment="Accept all chains" connection-state=established,related
add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" \
    connection-limit=30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment="Port Scanner Detect" \
    protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR S\
    UBNET IN THE SUPPORT ADDRESS LIST" dst-port=8291 protocol=tcp src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=bogons
add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment=\
    "Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=25,587 limit=30/1m,0 protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" connection-state=established
add action=accept chain=input comment="Accept to related connections" connection-state=established,related
add action=accept chain=input comment="Full access to SUPPORT address list" src-address-list=support
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood, adjust the limit as needed" icmp-options=8:0 limit=2,5 \
    protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP protocol=icmp
    "Drop anything else! # DO NOT ENABLE THIS RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED" in-interface=vlan1000
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=vlan1000 src-address-list=InternalSubnet
Is it an excerpt from the configuration?
Are you using a switch as a router? If yes, then do not be suprised. It’s a switch with router funcionality for maximum a “moderate” Internet trafic.
You can’t route on a CRS. Those are switches, not routers. They don’t have adequate CPUs to route traffic.
Are you sure? So why Mikrotik publishes routing results for that model?
“No adequate” does not mean “no possibility”.
https://mikrotik.com/product/crs510_8xs_2xq_in#fndtn-testresults
On results it shows
upto 32509, what does that mean?
Routing 25 ip filter rule
(Fasttrack L3HW) 32509.7 394798.1 93984.8 384961.9 288803.4 157109.0
It is from configuration, yes.
look at this video https://www.youtube.com/watch?v=c2sAA6jMjCY
It means that when Fasttrack + L3HW offload is active for 25 rules then the result is.
Look at the Routing table where typical routing speeds are shown. The max value is @420Mb so your 300Mb is getting close to that result. No suprise that CPU starts to get problems.
Once more: switch for (very)fast switching, router for (very)fast routing.
You’re using a switch, not a router.
However, you can hw-offload fasttrack connections to achieve the L3HW routing results, you need to change this rule:
to
add action=fasttrack-connection chain=forward connection-nat-state=srcnat connection-state=established,related hw-offload=yes
I would also recommend removing the connection-nat-state filter, unless you only want to fasttrack WAN.
However, not all connections/packets can be fasttracked, and those will still hit the CPU.
But with hw-offload you should definitely see much better results.
just another case of “using a switch as a router”
