cpu uses 90-100% in 19-20 Hotspot users
Hi
i have a RB493G router in my network and with only 20 active hotspot users the cpu uses is 100%
have sent the support.rif to mikrotik Ticket#2013011666000268 can any one suggest what to do
  • Use the profiler tool to find out which subsystem(s) are using so much CPU; and
  • The logs may contain some useful information.
already solved the issue
Admins please close this thread
Any follow-up on what the problem was, for the benefit of the next guy?
Deleted because not related.
it’s simple
i was using layer 7 based traffic shaping
so when user was using a protocol that is towards the last of the mangle rule it used a lot of cpu
SOLUTION
i removed the mangle for the protocols that are not being used in our network
