I always used RB133 moterboards for wireless. I check out that when traffic reaches about 14 Mbps in both directions (Rx and tx), the cpu utilization reaches 100%.
Moreover, when traffic is cut completely the cpu utilization has an average of 50%, which I beleive is to high for the motherboard in idle state.
My question is, can I shutdown any unnecesary process (like bgp, dhcp, all the things that comes with the OS) or should I buy a more powerfull cpu intensive motherboard such as rb333?
I never get cpu utilization below 2%. Only when wireless card is disabled by soft or when wireless link is down. When wireless is up it stays an average of 50% at idle state. When I load the link with traffic it reaches 100%, at 20 Mbps in one way, either transmit or receive
Onother test I done with rb133, is with dual-streme. (2 radio cards per RB133)
Instead of doubling the throughput it also, stays throughput at 20-22 Mbps in one way and 12 Mbps in both ways. In all cases at 100% cpu utilization.
I dont see improvement in dual-streme.
Packages installed: I also tried to disable all unnesary packages, routing, security, dhcp, hotspot, etc, and did not get any imrpovement.
Test enviroment: Rb133, some units with one wireles card SR5 (ubiquiti), and other rb133 with 2 cards SR5. (also notice that average cpu increases when having 2 cards even though the second card is not loades with traffic)
I tested rb 333 and got throughput up to 30 Mbps half duplex and around 15 Mbps Full duplex.
Then I tested dual-streme and got 60 Mbps half duplex and 30 Mbps full Duplex.(doubled the speed) - (CPU average 60-70% and notice in few rare ocations reaches peaks of 100%)
This improvementet is excelent!, though I can not get the 54 Mbps that some peaple claim, and the 108 Mbps in dual extreme.
Anyone got more throughput? why can I not get 54 Mbps with one radio card.
Does some one at Mikrotik answer this question?
